Why Snow Blower Storage Matters After Winter
When Is the Right Time for Snow Blower Storage
Preparing Your Yarbo: Clean & Dry Thoroughly
Remove all snow, slush, salt, and debris from the auger, chute, housing, wheels, and any metal surfaces. Salt in particular accelerates corrosion.
Use a damp cloth or a low-pressure hose (if manual advises) to wash the exterior. Then air-dry completely — trapped moisture is a leading cause of rust.
If there are places where water collects or snow used to accumulate (like under the chute or auger housing), pay extra attention to dry them out thoroughly.
Fuel Care: Drain or Stabilize the Gas
Drain the fuel tank completely by running the engine until it stops, then drain any remaining gas in the carburetor bowl (if accessible). This ensures no old fuel remains to degrade.
Use a fuel stabilizer before storage (if manual allows). Add stabilizer to fresh fuel, run the engine for a few minutes so the stabilized fuel circulates through the system preventing gum deposits during storage.
Engine Maintenance: Oil Change, Spark Plug & Cylinder Care
Change the engine oil (if recommended by the manual). Old oil can leave residue and degrade over storage, harming components.
Remove or inspect the spark plug. Some owners remove the spark plug to prevent accidental starts, or if storing long-term.
For added protection: some manuals recommend pouring a small amount of clean engine oil into the cylinder (via spark-plug hole), then cranking the engine to distribute the oil. This coats internal surfaces and helps prevent internal corrosion during long storage.
Lubrication & Rust Prevention for Moving Parts
Spray or apply light machine oil or silicone-based lubricant to auger shafts, chute controls, bearings, wheel axles, cables, and linkages.
Coat any exposed metal surfaces (chains, springs, bolts, skid shoes, blades) with a rust-preventative spray or light oil — especially if storing in a metal shed or unheated area.
Choosing the Right Snowblower Shed or Storage Space
Opt for a clean, dry, well-ventilated shed, garage, or storage area. Avoid damp basements, unventilated metal sheds, or outdoor areas exposed to moisture.
Maintain stable temperature — avoid spaces that get extremely hot or cold, or have high humidity. Extreme temperature swings degrade rubber and plastic parts, and accelerate rust.
If possible, designate a dedicated winter-gear corner or zone in your storage area to keep your snowblower and accessories organized.
Covering and Elevating Your Snowblower
Use a breathable cover (not plastic tarp) to shield the snowblower from dust, debris, and light moisture. Plastic covers trap condensation and can promote rust.
Elevate the snowblower off the ground use wooden blocks, a mat, or pallet to avoid direct contact with concrete or moisture-prone floors, especially if the shed is unheated or might get damp.
Why Storing Yarbo Properly Saves Time and Money
Preventing engine problems and expensive repairs — avoiding gum buildup, carburetor issues, or rust-related failures.
Extending equipment lifespan — well-maintained machines last many seasons longer.
Ensuring reliability — no surprises when snow strikes; quick start, smooth operation.
Saving time and hassle — fewer maintenance headaches, less downtime, lower replacement costs.
A1: It’s not recommended. Outdoor storage even under a tarp exposes the blower to moisture, temperature swings, and pests. A breathable cover in a dry, ventilated shed or garage is far safer.
A2: Both are valid draining fuel removes risk of gum formation; using a stabilizer and running the engine ensures smoother startup later. Pick the method compatible with your owner’s manual and local storage conditions.
A3: Yes, especially if the blower will be stored for months. Changing oil removes old degraded oil that might cause corrosion and ensures fresh lubrication for next use.
A4: Moisture from concrete may lead to rust on metal parts, especially the auger housing and underside potentially damaging components over time.
A5: It’s wise to check at least once every month: make sure the space is dry, the cover is secure, and there are no signs of rust, pests, or moisture buildup.
A6: As long as it's dry, well-ventilated, and doesn't get extremely damp, unheated storage is fine. Just ensure you elevate the machine off the floor and use a breathable cover to minimize moisture exposure.
Du är nu prenumerant!
E-posten behöver kontrolleras
Kontrollera om e-postadressen
stämmer.
