How do robot lawn mowers work
Thinking about ditching your push mower and huge riding mowers for a smarter option?
How do robot lawn mowers work, and do robot lawn mowers work well enough to replace traditional mowing?
This guide breaks down everything you need to know, from lawn mower setup to advanced navigation, efficiency, and maintenance, helping you decide if a robotic mower fits your lawn and lifestyle.
Spoiler: It’s more than just automated mowing—robot lawn mowers, like the Yarbo, redefine yard care while giving you your weekends back.
What Is a Robotic Lawn Mower?
Before understanding how robot lawn mowers work, it helps to define what they are. A robotic lawn mower is an autonomous, battery-powered machine designed to maintain your lawn with little to no manual effort. Using sensors, GPS, and smart software, it operates independently, trimming grass on a regular schedule without supervision.
Traditional robotic mowers relied on buried boundary wires to stay within mowing areas. However, next-generation models like Yarbo’s RTK-GPS robotic mower eliminate boundary wires entirely, using centimeter-level satellite positioning to map and navigate lawns accurately.
This shift makes robotic mowers practical not just for small yards, but also for large, complex properties.
The Technology Behind How Do Robot Lawn Mowers Work
So, how do robot lawn mowers work in real-world conditions? It comes down to a combination of mapping, navigation, automation, and smart power management.
  • Mapping Lawn: They use GPS wireless mapping technology to navigate your lawn.
  • Navigation: Sensors + GPS + cameras map your lawn, avoid obstacles, and plan mowing paths.
  • Operation: Frequent, automatic trimming keeps your lawn tidy and healthy.
  • Smart Control: Manage everything via an app — set schedules, check progress, and customize mowing zones.
  • Battery Power: Eco-friendly, rechargeable batteries eliminate gas and oil messes.
Advanced models like Yarbo even use cameras and AI to patrol your yard for extra safety.
So, how do robot lawn mowers operate in practice?
After the initial setup and mapping, your robotic mower automatically leaves its docking station according to your scheduled settings. It systematically navigates your lawn using GPS and onboard sensors, adjusting its path to avoid obstacles, pets, or children while trimming your grass with sharp, energy-efficient blades.
Unlike traditional mowers that remove large chunks of grass, robot mowers frequently cut small amounts, leaving fine clippings on the lawn to naturally fertilize your grass. When the battery runs low, the mower automatically returns to its charging dock, recharges, and resumes where it left off, ensuring consistent, even coverage without manual intervention. With advanced models like Yarbo, this process is enhanced with RTK-level precision and AI-powered obstacle recognition, delivering a truly hands-free, smart lawn care experience.
Do robot lawn mowers work on all lawns? Advanced mowers handle slopes, complex lawns, and large areas using systematic GPS-guided mowing rather than random navigation for better coverage and efficiency.
Technological Advancements in Robotic Mowers
  • GPS & RTK: Precise, wire-free navigation.
  • AI & Cameras: Advanced obstacle and boundary detection.
  • Smart Home Integration: Control with Alexa, Google Assistant, or the Yarbo app.
Lawn Mower Setup: How to Set Up a Robotic Mower
Setting up your Yarbo Lawn Mower is designed to be effortless and user-friendly, even for first-time users.
  1. Choose the Docking Location
    Place the wireless docking station in an open, level area with strong satellite signal access.
  2. Power Up the Docking Station
    Ensure it’s connected to a power source and functioning properly before proceeding.
  3. Install the RTK Antenna:
    Place the Yarbo RTK base station near your yard.
  4. Connect via the Yarbo App
    Open the Yarbo mobile app to begin the guided setup process—no technical skills required.
  5. Map Your Lawn Using RTK Technology
    Use the app to initiate RTK-based boundary mapping—no perimeter wires needed.
  6. Define the Working Area:
    You need go around with your robot lawn mowers using the app and define the areas your want it to mow, know are the working zones, you can set up up multiple zones as well as the no go zones.
  7. Calibrate and Customize Settings
    Adjust the cutting height, mowing schedule, and zones as well as the mowing patterns directly from the app.
  8. Finalize Setup and Test Run
    Complete calibration and run a quick test to ensure everything is functioning as expected.
  9. Enjoy Smart, Hands-Free Mowing
    With setup complete, Yarbo will take over your lawn care with intelligent navigation and automation.
This lawn mower setup ensures efficient, hands-free mowing aligned with your yard’s needs. Yarbo's 24/7 customer support and after sales customer care team is there to help and guide you each step of the way.
Key Components of a Robotic Lawn Mowers
  1. Power Source
Most robotic lawnmowers run on rechargeable lithium-ion batteries, which provide a quiet and energy-efficient alternative to traditional gas-powered mowers. These batteries typically last 60 to 120 minutes per charge, depending on the model and lawn conditions.
  1. Cutting Mechanism
Unlike traditional mowers with large rotary blades, robot mowers use small, high-speed spinning blades or razor-sharp discs.
This allows for a cleaner cut and promotes healthier grass growth through mulching—where tiny grass clippings fall back into the soil as natural fertilizer.
  1. Navigation and Boundary Definition
Robotic mowers rely on different navigation methods to stay within their designated mowing area:
  • Boundary Wire Navigation: Many models require a physical boundary wire installed around the lawn's perimeter. This wire creates an invisible fence, guiding the mower and preventing it from straying into driveways, flower beds, or neighboring yards.
  • GPS and RTK Technology: Advanced robotic mowers now use GPS-based mapping, with some incorporating RTK (Real-Time Kinematic) positioning for centimeter-level accuracy—eliminating the need for boundary wires.
  1. Sensors and Safety Features
Robotic mowers are designed with built-in safety features to prevent accidents and ensure smooth operation:
  • Collision Sensors: Detect obstacles and change direction to avoid hitting them.
  • Lift and Tilt Sensors: Stop the blades immediately if the mower is lifted or tilted to prevent injury.
  • Rain Sensors: Some models automatically return to their charging dock when it starts raining to avoid damaging wet grass.
Benefits of Using Robotic Lawn Mowers
Saves Time & Effort: Completely hands-free lawn maintenance. Eco-Friendly: Runs on electricity, producing zero emissions. Healthier Lawn: Frequent mowing encourages thicker, greener grass. Quiet Operation: Much quieter than gas-powered mowers. Smart Features: Can be controlled remotely, scheduled, and monitored via an app.
Cost and ROI Analysis
Category Price Range Ideal For
Entry-Level $800 - $1,500 Small lawns (under ¼ acre)
Mid-Range $1,500 - $2,500 Medium lawns (¼ - ½ acre)
Premium $2,500 - $4,000 Large & complex yards (½ acre+)
While the upfront cost is high, homeowners save $600–$1,000 annually on professional lawn services and maintenance. Learn more about the cost of robot lawn mower vs. Manual lawn care.
Tip: If your lawn care expenses exceed $50/month, a robotic mower can pay for itself in 3–5 years.
Robotic lawn mowers are transforming lawn care with advanced navigation, eco-friendly operation, and smart features. Whether you have a small yard or a sprawling lawn, these innovative machines save time while keeping your grass perfectly trimmed.
If you are having trouble deciding on which lawn mower would suit you based on your lawn size. Read our guide to make an informed decision.
Thinking about upgrading to a robotic mower? Explore your options and find the best model for your yard today!
Common FAQs About Robotic Lawn Mowers
  1. Do robotic lawn mowers work on uneven terrain?
    Yes! Most models handle slopes up to 30-45 degrees, though high-end versions with all-wheel drive tracks can tackle steeper inclines.
  2. Can robotic mowers handle large lawns?
    Yes, depending on the model. Some can mower such as Yarbo can mow up to 6 acres using GPS-guided navigation and multiple charging cycles.
  3. Are robotic lawnmowers safe for pets and children?
    Absolutely! They come with safety sensors that stop the blades when lifted or when an obstacle is detected.
  4. Do Robot Lawn Mowers work in the rain?
    Most robotic mowers have rain sensors and will return to their charging dock if it starts raining. However, some models can operate in light rain.
  5. How much maintenance do robotic mowers require?
    Minimal maintenance is needed—just occasional blade replacement, wheel cleaning, and software updates.
Regular price 71 269,00 kr
Regular price 100 089,00 kr
Regular price 113 289,00 kr
